Hi,
I have a Sentra 87 coupe and the fuel pump doesn't work.
It's a new pump and my fuel level gauge work.
I just wan't to know what are the possible causes why my pump is not working.
Thx
you have a fuel pump relay and a fuse. i would check both before i do anything else.
I'm guessing this is an electric fuel pump eh? Because it was hard to mess up my mechanical pump install. lol
If your fuel pump is whining...then you need to check the pick up. If it isn't, then check the fuse. If that is good, then look at the wiring for pinches or damage to the sleeve. Make sure your connector on the pump is seated correctly. If all else fails and you start getting wicked impatient then put a 12v source directly on the pump to make sure that the pump didn't come DOA.
