I got a 1999 Sentra it cranks but it won't start. I think it might be flooded I need to know where the fuel pump fuse is my doesn't have the fuse diagram.
I went to take out the fuse and it was popped. I cranked the car to let the fuel out and I replaced the fuse the car still would'nt start. What would make the fuse pop?
Can you hear the fuel pump hum when the key is on? On a different note, I had a problem where my car cranked but would not start, it turned out to be the ignition rotor inside the distributor.
if you can hear the fuel pump humm, then the relay engages just fine. anyways, the relays are in the engine compartment above the passenger side wheel i think
1 - 10 of 10 Posts
Nissan Forums is the go to place to talk about your favorite Nissan model, including the Rogue, Maxima, Altima and even sports cars like the 370Z and 200SX.
