look at where the tube on the right side of the engine is that leads to the airbox/cai etc... where it connects to the engine look up about 3 inches..its the little metal circle with metal lines leading to the TB and to else where..tony200 said:i need to find out where the stock pressure regulator on 98 nissan 200sx is.
thanks
HUH? Dude you don't know where the stocker is and you have a stillen adjustable regulator? Anyway why do you have an adjustable FPR? You realize that if you raise the FP you will likely lose HP? Or that if you lower it too much you can run lean? Honestly without big mods. it is kind of a waste as to adjust the pressure correctly you need to use a wideband O2 sensor to see where your AF ratio is and adjust it from there. Otherwise the stock FP is fine for what you are running.tony200 said:guys i have a stillen adjustable fuel pressure regulator.
Yes it should stay at stock pressure if the nitrous is set up correctly. 43.5 PSI without vacuum. What are you doing for fuel on the N2O system?tony200 said:with a 75 shot of nitrious?
My question is how does the zex wet system add fuel? If it has a setup to take care of it why would you want to add the walboro and raise the FP?tony200 said:listen im trying to find out information about the fuel pressure regulator. for the setup im using, its a zex wet system. i would like to put in a walbro 255lb pump as well to make everything safe and run right . so i was seeing if i could turn up the pressure to at least 47 psi to run a good mixture. is this possible? cause running a 75 shot does require modding the fuel.
You are not making 125 WHP now, and usually you do not gain EXACTLY the amount of spray you are running, pretty close but not necessarliy exact.tony200 said:please excuse my comment wes but what makes you think that i wont hit over 200whp with a 75 shot? just out of curiousity.
A fully bolt-on GA16DE makes about 115WHP (90WHP stock). A 75 shot adds about ............ [wait for it] ................ 75WHP. That adds up to 190WHP max.tony200 said:please excuse my comment wes but what makes you think that i wont hit over 200whp with a 75 shot? just out of curiousity.
