I hope im posting this in the right spot. I have a 93 sentra xe 1.6L. The other day I pulled it out of the garage and parked it. It was cold but its been out in the cold before with no problem. Later that night I put it back in the garage no problem. Next day it wont start. Turns over fine. I pulled the fuse for the fuel pump to de-pressurize the fuel system so I could take the hose off the fuel filter to check it. After pulling the fuse and turning it over to de-pressurize, it started! It died after a few seconds of course. I put the fuse back in thinking its working now and its back to just turning over but not starting. Pulled fuse back out and almost starts again. Anyway, I did verify fuel coming out of the filter so could this be a pressure regulator problem?
Discussion Starter · #2 ·
After doing more research on this awesome forum I found out it was flooded and did the "hold the pedal to the floor and start it" routine and it worked! I'll see if it starts up after about an hour. Thanks!!
