yep....problem.... :wtf: .....anyways.....here's a situation.....i'm drivin down the road.....fuel gauge reads 1/2........then at a stop or while drivin a minute later....it'll drop in between 1/4 nd 1/2.......then a minute later it'll come back to 1/2.....nd it'll keep on doin that.....anyways...i guess the float in the gas tank is gunked up (i wouldn't kno how or why?)......or someting related to it.....anyways...oh yea.....nd when i start up the car......i may have what i THINK is 3/4 of the tank full.....but the needle on the gauge cluster takes like 2 minutes to stop rising.....too slow i think....anyways....any suggestions?.....
· Nissan/Mazda Gumshoe
mille-16i said:
Search the forum you will find many good threads on this matter. You may have a voltage regulator going bad that seems to be the biggie on the B12.
i agree, its about 40 bucks from the dealer or you can go to the jy and pay 10 or so for it and replace it again in about 6 months like me :rolleyes: . basically, pull the cluster and remove the silver box(black boxs with fins on some) and bolt back up the way u took it off. 30 minutes for most, good luck! :cheers:
any pix?.......so i kno exactly wat to look for :rolleyes:
no, sorry but if u do a search one of the threads i know for sure has pics. hint: only box on the back of the cluster :cool:
· Tha Sleepin' B12
I have this exact same problem but ALL the other gauges read fine so you might just want to have that floater checked if it's the same for you. I know I just put a brand new voltage regulator in about a year ago, I'm not sure but shouldn't it still be good? Or do these run out quicker than I think?
