So the fuel filler door won't close on my 2002 Pathfinder LE. Turns out the little plastic-over-metal bolt that holds the cover closed is broken (it's the part that moves/retracts when you push down on the lever to open the latch).
Anyone know if this is easily replaced? Or what it's called/part number?
As a last resort I guess I can McGuiver something if it's too expensive to replace.
