Cool thanks, good explanation. :thumbup:mpw991 said:It you look at the picture of the cable close up there is a piece of plastic in between the metal swing arm and the bottom half of the cable. This little circle of plastic was originally part of the upper section of the cable. It was connected to the molded plastic part at the of the protective covering for the cable. What happens when you push on the fuel door release is the protective cover is pulled to the front of the car and the piece of plastic that once used to be connected to it pulls on the metal swing arm. This then pulls on the cable to the right and opens the fuel door. When the plastic part breaks away from the rest of the cable there is nothing to pull on the metal swing arm anymore, thus the fuel door doesnt open. I hope this explaniation is clear enough. Later today when I get back to my desktop I will highlight the plastic piece and work with the picture a little to make it a little clearer. On how the motions actually work.
