http://www.boostcruising.com/silvia/eprom.asp
i read that webpage (the last part) were it tels how to calculate the new injector konstant
and asuming the CA18DET has 370cc and I bought 1000cc
370 / 1000 = 0.37
12A (298) * 0.37 = 110 = 006E (hexa value)
(read the last part from that link so u can understand the calculation done here)
acording to that web page if i buy and replace the stock injectors with 1000cc injectors, and change in the ECU CHIP that data (i can do that i have all the necesary hardware - and i have also that software) the car should run just fine
true or not?
(to be more specific: if i replace the stock injectors with 1000cc injectors no other mods done to the engine and on the ECU CHIP i change that data acording to this calculation .. the engine will run ok?)
PS: no need to talk about the waste of money, the ideea is that if i buy new injectors and replace the stock ones, to do this like one time job (i replace the stock ones with new ones and even my engine has 169HP or 500HP to be confident that my injectors will do their job - we do not talk about fuel presure fuel pump... only about the injectors)
