07 pathfinder
drivers side window stopped working with window half way down. I have taken the master door switch out and apart dried it out reassembled and it didn’t change anything. About same time passenger front window started intermittently not working. It came down and after several different attempts with both switches finally got it up. At that time everything worked but drivers window. When I hit the switch it would make a small click so figured it was motor. Took door apart and ordered new motor and rail but got the 2 pin and my mine is six pin. Ordered just motor and installed it. Now both windows will not work and door lock buttons on both sides don’t work. The back windows still roll down and up fine. Have a new driver side switch and the new one does same as the old one. I have looked at fuses but it doesn’t appear as bad. What is causing this issue where the front is not working but back windows are not affected?
Originally posted in the other pathfinder forum for newer pathfinders. I have disconnected the battery for over an hour and rebooked and no different results.
