I'm having some weird problem with my front passenger power window. IT goes down but not up. It's making a terrible grinding noise. I opened up the door and got it going or so I thought but now it's doing it again. The motor and switch seemed to be working fine. Is it possible that it's not on a track or something? This is the first time I've had this problem.
That grinding noise you are hearing is most likely the worm-drive shaft of the motor slipping on worn out plastic gear teeth of the motor gear box. I've replaced three on mine and that was the problem with all three. Car had 160k on when I got it and I use the windows a lot delivering mail so they tend to fail a lot for me.
