well today, after reading the sticky on replacing the front oil seal, which was leaking on my 94 XE with the 1.6, I decided to take on the task. here's what I did:
(1) removed drive belts. power steering/water pump belt is a fun one.
(2) removed crank pulley nut and crank pulley.
(3) taped the tip of a small screwdriver, and pried the old seal out.
(4) sprayed some brake cleaner in the bore to clean out the old oil. wiped it dry.
(5) brushed some permatex hi-tack (said on the can, good for "oil seals") on the new oil seal
(6) placed it in tbe bore, took a socket (which I fear was a little too small) and gently tapped it until the seal was flush with the timing cover surface.
now I realize it's not good practice to start the engine without reinstalling the crank pulley and belts. particularly cos with no alternator or water pump, the little red charge indicator light stays on and the engine overheats before too long. but when I did so, oil was literally pouring from around the inside of the seal. what could I have done wrong? I've done it before in an 88 maxima with no problems. I think the socket I was using to press it in was too small cos it wasn't exactly the outer diameter of the seal. but I'm on my way to a store now to get a new seal, and something the diameter of the seal to press it in with, maybe a piece of exhaust pipe with the end taped? I really need to get this fixed and don't want the car sitting on a jack in front of my house, on the side of the street, all torn apart.....
thanks
Dan
1994 Nissan Sentra XE, 5-speed, 143,000 miles
1994 Nissan Sentra Limited Edition, automatic, 210,000 miles
thanks
Dan
