My old and dependable farm truck is leaking oil in the front of the enigne, near the main shaft. Is this a difficult seal replacement? The oil has slung from the leak has fouled up the alternator ( I think). It now has the charging light on. I will need to pull the alternator, but would also like to get that leak stopped. What must come off to replace the seal? Thanks for your help.
Without going out in the snow to look at mine,just off the top of my head,you maybe be able to just remove the radiator and fan shroud,to make room for the puller.The belts and balancer pulley, might be the only other things.It may be a little tight,but doable.
Good Luck
