I have just replaced the headgasket on my 88 GA15E Pulsar and found the front main bearing is leaking like a mo fo. As in drip drip drip all gone in 30 minutes of driving.
Can anyone advise me on what is required to replace the main bearing/seal? Is there an external seal at all or is it just a bearing?
Do I need to completely dismantle the engine down to the block, or can it be done with a simple replacement of a seal from outside of the engine?
Thanks for any advice,
Still Nissaning
I'm not sure on the GA15E, but on the GA16 it has a seal that can be accessed quite easily. Do you know if you have a timing chain or a belt? If it is a chain, your seal will be on the outside and accessable by pulling the lower main crank pulley. If it has a belt you will most likely have to pull the timing cover, and the lower timing sprag to get to the seal.
