can explain it to you, black wire to link the neg on the 2 lights and then the black wire goes to the switch, then a positive to a power source (IE: parking lights or battery) (there is a 2nd neg terminal on the switch for ilumination, that gets grounded so it will light up)
Your state laws may require that the fogs only work with the low beams so you would have to hook them up that way which means that you will need a relay as well. Most fog lights come with wiring instructions.
