1 - 8 of 8 Posts
With a faster car, requires better lighting. So this is what I came up with:
- Aftermarket R34 headlights in full chrome
- FX bi-xenon projectors mounted on the outside for high and low beams with clear lenses and color mods
- TSX low beam projectors mounted on the inner side that stay on with the low and high beams
HID ILLUSIONZ [new york city]: Nissan Maxima R34 HID Quad Projector Setup Retrofit Headlights
I am using a separate 9004 to bi-xenon harness per side and 4 D2S slim ballast HID kits (from Liuspeed). They should be on the car in about 2 weeks.
L
Yes. It will be very bright. All 4 will also be on when I turn the high beams on. The only thing the high beam switch will do is open the shutters on the FX projectors. The harnesses I am using have 3 relays: 1 to switch on the low beam lights, 1 to keep the lights on in high beam and 1 to open the shutters.
· MODR H8R
I was just wondering. Im assuming because of the FMIC that you dont have fog lights. Legally I dont think you can have more than 4 foward facing lights on on the car.
So when do you project this being finished?
I don't have fog lights. I do have driving lights. I have a pair of CATZ MSP driving lights in the outer sides of the center opening in front.
Here are the laws for the state of Texas:
1. You must have at least 2 forward facing headlights, at least 1 per side
2. There is no restriction on the number of forward facing headlights
3. Auxillery lighting is not restricted
There are a lot of cars that have quad beams from the the factory, including BMWs, Jags and older GM cars. If you buy a Mini Cooper, you can order it with a factory installed grill mounted auxillery headlght kit with 2 or 4 additional lights. There is also not a restiction having a low beam light on in combination with a high beam. My 996 headlights have a halogen low beam that turns on whenever the high beams are activated and the bi-xenon shutters open. On the other hand, it is illegal to operate an automobile in the state of Texas with less than 2 operating headlights. It is also illegal in most populated cities to operate high-beams within city limits.
1 - 8 of 8 Posts
