Huba hubbah. . . Greg Vogel is a Nissan Performance Specialist currently employed at Mossy Nissan in Oceanside California 1-866-556-6779 he, or Steve Cristianson (formerly of Nissan Motorsports) could assist with any information regarding the E16ET.
As for the parts being installed on a N/A E16S or E16I with these age of these motors, you may want to consider freshening up the seals before you start bolting kits (though this is OEM, for this application it still qualifies as a bolt-on kit) onto these aging motors with weak seals. I'm sure if you were able to get it just like the Nissan Motorsports sr20 starter kit which has all of the parts for the GTi-R t28 you could order them from a dealer too for the E15ET or E16ET as a turbo starter kit (heat sheilds-manifolds-turbo-oil hoses and a bit more and you have the kit) still gonna pay NEW money for it $1,500.00 + the sr20 turbo kit from Nissan is close to 2k bucks, though it's factory new.
Possibly the USDM Pulsar w/E15ET ECU could run this motor (or the swapped parts over to USDM N/A E16S or E16I motor) and make it work. Nice to to see it, though with the money it would cost to make it happen, if you are going to boost an E series motor. . . Save lots of time and aggrivation and get the USDM Pulsar motor & ECU you can find in any boneyard and the USDM engine harness to run can be purchased over the counter NEW at any Nissan dealer. If you want to make it easier?
