so here is muh prob. I hit a speed bump last week :mad: and since then muh header has been vibrateing like a MO FO. But Neways I know its the part that conects to the cat and I can see where it slid over and was resting on the sway bar so I moved it off the sway bar and the vibrating stopped. But see the thing is that now muh car glides when I drive it just dont have the torqe that it used to. So muh Q is this why is this whats happening and how can I fix it. SORRY SO LONG AND BORING, BUT THANX FOR YOUR GUYS HELP
Discussion Starter · #2 ·
for one ur car prob drifts b/c u knoced the alignment off. and as far as the torque maybe u have a leak... i would need to know more than wut u wrote.for instance is the car loud now?
Still moderating..sorta
Can both of you try to spell words correctly and write with something that remotely resembles english grammer. Your posts are really hard to read
my car dont drift. It just glides when I drive not in a bad way tho. Ijust dont have the "get up and go" i used to have. and no its not louder and no there are no cracks on the pipes or anything like that..
Ex-mod/nissan guru
have you check your exhaust manifold ??... should the downpipe hurt the ground it could have make a leak there !! :)..
check if you can rethithen those bolts and check the manifold to downpipe to... could be a small leak...
