You can't just swap the engine.
-The Max engine won't bolt up to the B15 trans, so youll need to use the Max trans or fabricate an adaptor plate.
-The front track of the Max is 60in. and the B15 is 58in, so you'll need to fabricate axles.
-The engine/trans mounts will have to be fabricated.
-Since the V6 is wider then the I4, there may be problems with the engine hitting both the firewall and the radiator.
-You will need custom exhaust manifolds and exhaust system.
-The B15 radiator may need to be upgraded to handle the additional power.
-The front springs will need to be changed to handle the extra weight of the V6 and trans.
-You will need the Max ECU and wiring harness.
That's all I can think of off the top of my head. There are probably other things just as important.
Lew
Not Anymore.
Lew
My point exactly :) It can be done but it would be kinda senseless. If you are looking for more power, have you started with bolt ons to see if they suit your fancy?
wow. . . since the sentra spec V is already horrible with the weight distribution
I think it's like 60/40, correct me if i'm wrong, cuz i think i am. lmao
but i can't imagine all that extra weight in the front of that spec V it's like an extra 200-400 lbs. . . is it worth the swap? i think not !
have a nice day
:banhump:
QUOTE]
i'm going to correct myself . . . sorry spec V 05 is 55/45 distribution
not bad not bad
but still the extra poundage in the front will put it around 60/40
