Hello new to this form first post
I’ve just picked up an 03 Murano with possible bottom end bearing issue. Can the upper aluminum oil pan be removed with engine in the car? Looks like no problem just pull starter and lower metal pan then inner and outer bolts?
I have to check crank bearings.
Second question will a 09 Murano bottom end short block fit the 03?
