1 - 7 of 7 Posts
hey i have a little bit of money and was woundering what i should do about getting a new or rebuilt engine with out spending too much, i'm gonna change the tranny at the same time so could i put in a an engine with a turbo even though my car doesn't currently have one? how east will it be? thanks for the help
· Z31 know-it-all
what's wrong with the engine that's currently in the car?
whats wrong with the engine?
nothing to major just a couple of oil leaks and i overheated it pretty bad one time one of the spark plugs worked its way out and i thought i blew the engine, i just done have the no time or space to work on it and im in Las vegas so its not even cool enough at night to work on it. i'm confident in my mechanical abitlitys to swap out the engine in one day. i can handel one day of 110 temp working on a car. plus i need the car i cant have it not working for too long, i would love to put in an early 90s turbo engine but i dont think that will be easy. i'm not gonna change the tranny i was thinking ill just change the clutch cause i know it needs to be done sometime soon and i might as well do it when it will be a lot easyer to do it.
· Z31 know-it-all
run a compression test first. if the numbers are fine, it's a waste of time and money to replace the engine. oil leaks are simple if you have any mechanical abilities.
You could buy a full turbo kit and maybe get more power for the money, but make sure you engine is in good enough condition to handle the boost.
· Z31 know-it-all
1 - 7 of 7 Posts
