1 - 7 of 7 Posts
Sometimes when I let my Spec V idle, it will stall and kill, other times it will just hesitate for a second and fire back up. The power goes out for the second and some times the trip computer will reset (I think the ECU as well but I am not sure). Has anybody else had this problem? It seems to have started after I relocated and grounded my knock sensor. Is there a way to ground it incorrectly or could a wierd vibration (Bass from Stero, etc.) on the fire wall cause it ti retard the timing at idle. Please help it is getting old. Other engine and electrical mods are, HS CIA, HS Header, NX, amp and subs
Is your air filter clogged or dirty? That might cause the engine to bog itself down a little.....probably a wrong suggestion, but it's a suggestion nonetheless...
Knock sensor
If you dont ground it i dont think it will run properly so make sure you have a really good ground. 90% of the time whenever i have had an electronic problem It was ground related.
I ground back to the screw that the neg battery goes to.
about few weaks ago
1 - 7 of 7 Posts
