my car will stall at stop light while the gear is in 'D' and the brake is depressed... i search over the net and most people suggest the brake booster is bad... one of the method to check is to depress the brake while the engine is off... then start the engine and the brake pedal will go down slightly... but in my case.. the pedal went down a lot.. almost to the floor i would say... what could be the problem...??
