1 - 20 of 26 Posts
Hey All,
My car is making a popping sound. It happends when Im driving thru first and second gear. After that it sounds fine. At idle it sounds fine. But also while im in first, not going any where, it sounds poppy. I know thats not much to go on. If you can give me opinions on what you think it might be. I have a few guesses but am not sure.
Thanks,
Katie
95' Maxima
see i was thinking it was an exghast leak. just cuz it sounds like it coming from the back under side of the car but the engine is also rocking a little bit... when its in first gear... and im not going anywhere.
The other thing i thought it could be was a misfire at a piston..... but ???
Im in Carrollton.
The car was driving fine yesterday and last night, then I went out for just a little while today and thats when started....
In Ur Threadz - Deleting!
No check engine light?
So this only happens in 1st and 2nd?
What mods do you have?
Always put 93octane in?
Last tune-up?
Can you feel any weird vibrations?
Does the engine sound like a Camaro?
Ya'll are gunna hate this.... yes check engine light is on, been on for a long while now. Codes were run by bluebob at a meet a long time ago, said it was the engine temp sensor.... but i think more is wrong now.
Thats all that i noticed, yes
Intake and exghast
no, 89 thats all I ever used in it (yeah, yeah thats bad) didn't think it was to bad till the last meet when i was told it was bad
Last tune-up?
ummmmmmm..... I think 90,000 miles.... its at 128,000 +/- now
yes, in the stering wheel and see the hood shake a little
It does sound different.. like a camaro.. ehh i don't know. Im gunna take it to Autozone and have them run codes.
Thanks for helping me try to figure this out.... im hoping its nothing like a blown motor.
Im in Carrollton.
Since it's gear-sensitive, it probably wouldn't be a misfire or that sort. Check and see if it has anything to do with the speed you're going. Other than that, try running the codes again.
Autozone
Okay i went to Autozone and they couldn't run the codes bcuz they didn't have the ODM 1 just the 2. They said check o'riellys. They didn't even have a nissan adapter... Today it was happening in all gears.. even just cruising in fourth at 40mph. It didn't start untill the car was warmed up. Thanks agian you guys. I hope to get whatever the problem is worked out.
I thought all 4th gen maximas were OBDII...even though it's a 95?
dfwgirl81 said:
i don't know, the guy came out to my car, took a look and said no it won't work.
When I get back from Austin I can pull the codes for ya no problem. I won't be back till Monday. National SE-R convention this weekend WOOT WOOT.
Discussion Starter · #13 ·
*Thank you very much. Hope you have a fun time this weekend.
My car, tonight after I got off of work, was running much better... problem still there..... just not as bad.
...... mabey the colder weather at night. ;)
DNE's VZR Conversion
make sure your car is obd 1 or 2 by searching on the maxima.org... autozone people are stupid and said my car is an obd 1 when it is an obd 2 .. i remember when the autzone guy plug the lil code puller he said " HOLY SHIT YOU HAVE A 96 ECU IN YOUR CAR ?!! "
autozone people some are pretty much stupid... so i wouldnt trust them 100 %
95 should be OBDII. Standard OBDII scanner will pull codes. Try a different store.
and tell them that it is an obd 2 and make them come out there and pull it cuz that what i had to do.
Have ur boyfriend take it up there with his a$$hole hat on and TELL them how to do their jobs since they are idiots.
1 - 20 of 26 Posts
