Hi, sometimes when i break hard my lights, radio and electric power steering give out for about half a second, electrician had a look and claims the alternator was charging well, battery is new and had it checked and it performed as it should on all tests. Any ideas what could it be?
Sup Mod keeping the peace
Obviously there probably is some electrical connector that is loose. The prime suspects are the battery terminal connectors; disconnect them and clean the terminals/battery posts real good with a wire brush and baking soda/water. Inspect the negative battery cable ground point at the engine block for tightness and oxidation. Inspect all electrical connections at the alternator.
