starting my swap, for the guys that do a lot of fuel pumps and tank work. is there a year/make/model i can pull the entire fuel sending unit from and put into my 84? since the b12 came injected, was hoping the tanks all stayed relatively the same cause if so i have a line on a cheap sending unit without a pump that should work nicely out of a b12 if they fit and a pump sitting here already
or should i hack n tap with bulkhead fittings the stock tophat on the tank and run -6 lines and a inline pump for ease of installment?
havent gotten a chance to get to a jy to start hacking at things to take measurements and hoping one of you guys can tell me
