1 - 9 of 9 Posts
DNE's VZR Conversion
Does else have an EGR Valve problem like me and TeknoKid. Our EGR Valve doesnt work because of our exhaust system.
we both drive the 95-98 Nissan Sentra GXE. Has anyone have this problem before? and how did you fix it?
TeknoKid- - 96 Sentra GXE with 2 " piping
Me - - 95 Sentra GXE with 2.25 " piping.
Could you fill us in some more? I don't see a connection between piping size and EGR system. Is there a link to a previous discussion or something? :confused:
in^3,N20,RPM,PSI
Have you checked the valve? Have the engine running (warmed up) and reach your hand under the valve and push up slightly on the diaphram. If the engine starts to hesitate a bit it's working. There's a common problem (started another post earlier) with one of the little rubber lines right under the BPT that deterierates over time. It connects the egr and BPT together and it will fall apart in your hands if you haven't replaced it in a while. Try that first and let us know what you find.
i havent checked the lil rubber piping thing but i will check it out with TeknoKid. I took it to the mechanic and it said my EGR is fine it that since i modified my exhaust system it get no back pressure into it and not functioning.
ok thanx. i will try that. All i need to do is find out where the EGR valve is on my car.. hmm...
ok. thanx. so the thing is located under the throttle body. If the tubing is broken how do i get a enw one and how much. Do i need to get it replaced alot?
in^3,N20,RPM,PSI
Well the egr tube can be bought from a Nissan Dealership... don't know the cost. the tubing doesn't usually 'break'... shouldn't have to replace it...
1 - 9 of 9 Posts
