1 - 12 of 12 Posts
XTRAIL-HOLIC
Isnt it common practice on the X-T to remove/blank off the EGR, as It is known to crud up the sytem?
Depends on what exhaust system you're using I guess ;)
Mine is fine after 6 years of driving with an upgraded exhaust system and high flow cat converter, so it's not clogging-up anything.
I know a lot of the Mistsubishi/Vauxhall/Land Rover guys blank off the EGR and find it makes a significant improvement, both in performance and economy, particularly if any/all the crud is removed from the EGR system. Has anyone blanked off their X-T? I notice lots of kits for the above on e-bay, but none for the X-T, as yet.
XTRAIL-HOLIC
I thought the QR25DE has no EGR valve ... ???
I stand corrected. Been spending too much time working on my wife's Mazda and I thought I saw this EGR valve in my exy when in fact it was in her Mazda.
The QR25DE does NOT have an EGR valve indeed, instead it uses large valve overlap at cruise and under engine braking to suck exhaust gas back in from the exhaust manifold.
The diesel engine does have it though.
X-Trail Moderator
............The QR25DE does NOT have an EGR valve indeed, instead it uses large valve overlap at cruise and under engine braking to suck exhaust gas back in from the exhaust manifold.
Which was why there were engine failures in the early QR models because the fine particles broken away from the pre-cat core would get sucked back into the engine and "skratch away" the cylinder walls :)
1 - 12 of 12 Posts
