1 - 20 of 20 Posts
Banned
Since the last thread we had about this was a little iffy. Here's what the FSM says... If anyone needs a reference page posted please ask through PMs. All pictures are under 70KB a piece for you 56K users. I compressed them quite a bit.
Procedure to pull codes is as follows.
  • Like
Reactions: Zen31ZR
Banned
Sorry man but I see them all... the first 4 are attachements straight off the board. The last one is photobucket and they all work..
If anybody else is having problems please post.
  • Like
Reactions: Zen31ZR
Banned
Well that's what the FACTORY SERVICE MANUAL says. So I think it's probably correct.
Banned
Well I have worked on 1987 Maximas, 1988 300zx, 1987 200sxse and I assure you that it is not the correct procedure.
I have also worked on 1984/1985/1986 300zx.
Dropping codes on 87 and later vg30e Nissans is only done in mode 3. Unless the procedure tells the person HOW to even get to mode 3, then it is not correct.
The procedure you list is from a two mode only type ecu.
Banned
That procedure is from a 1986 Field Service Manual.
Its possible that your ecu is from a 1984-1986 car. Just drop it and if there are codes listed on the ecu box itself, then it is a 1984-1986.
If it does not have codes listed on the outside, its a 1987-1989 ecu. I take it you are not the origional owner.
Its very doubtful that Nissan would move Maximas, 200sxse and non-turbo 300zx to a new generation ecu and leave the 300zxt with an older technology.
Banned
Possible maybe somehow he was putting it in Mode 3 accidently. From what I saw of the mode change procedure in my 88 FSM, it's possible, but you'd have to get real lucky......
I'll change the title to reflect the earlier procedure.
I can also either make a seperate thread for the 87-89 procedure , or refer people to the FSM link, the section explaining all 5 modes and code retreival and testing procedures for the parts involved is incredibly long. Thanks for bringing this to our attention, BTW. ;)
Banned
Discussion Starter · #12 ·
Hmm that's something I would have to check out. No I'm not the first owner but the first owner wouldn't know how to change out an ECU. Maybe I was just lucky and it gave out the codes either way. I'll have to give it some more investigation.
Z31 know-it-all
For most countries, the ECU is in the passenger side kick panel.
NF Mod/Nissan Master Tech
It's not flashing codes, but modes. There are 5 modes; mode #3 is self-diagnosis. There should be a screw on the ECM which you can turn to enter the mode. When you enter the mode, the red and green lights will flash seperately to identify the code. IE, a code "32" would flash the red light three times and the green light twice.
I think now I did everything right and the codes are 22,21,41?
And they mean:
21-ignition signal missing in primary coil
22-fuel pump circuit
41-fuel temperature sensor circuit
Problem of my car is that it hasen't got the power it used to have and when accelerating it just jumps on the first gear but when the rpm's go up, the acceleration gets better and when the car is on neutral,it woun't work evenly and the rpm's go up and down 900-1700. (my car: nissan 300zx z31non turbo1985)
1 - 20 of 20 Posts
