I guess this is to much advance for a turbo car.
I tried connecting the vacuum advance to the manifold so it always has vacuum, and then i set initiall timming again to 10BTDC, this way the vacuum advance is always advancing to stock timing and when boost starts it retards 10. It was only a test, but i found out that the detonation i was hearing was less now, then i tried the same thing with initial timing at 5BTDC and the car was slower at low revs, but didnt have any trouble at high revs and couldnt hear any detonation at all. So i guess the engine liked to retard about 15.
This was just a test, but now its clear i have to do something with my timing, ill have to make some device that advances normally with stock timing untill boost starts and then retard about 15 which tells me that max advance with the data above will be about 20btdc with boost if i dont step hard on it it will work almost like stock.
What do you guys think?
