Hey guys, need some assistance here with my 97 pathfinder. Basically when going over rough roads or turning in driveways or parking lots I would get a clunking noise.
Now this doesn’t always happen. I can fall in the biggest hole (not that I do this, I try to avoid damaging suspension at all times) and it would make the noise. Or go over continuous rough bumpy noise and wouldn’t make it. Then sometimes it would, especially when going around turns with bumps or going in driveways not so slow.
I have put new suspension components both front and back. But focusing on the front I have done the control arms, ball joints, tie rods, tie rod ends, struts, sway bar bushing, sway bar links. This was all replaced a year ago as it was time for replacement and I did have a clunking similar that went away after new suspension.
I am having trouble locating the noise that occurs only on this side. And knowing the suspension is new makes it even harder.
Any help appreciated.
thanks!
thanks!
