Exactly where are the bolts to be loosened to loosen tension and remove the a/c alt belt and water pump p/s on a 1.6L? There are so many bolts. One whole with tensioner is easier to remove.
Also, to gain easier access to water pump, can I remove the upper engine mount and jack up engine?
Thanks. :showpics:
Thanks. :showpics:
