cwrr226 said:
i tried searchin but i couldnt find anything helpful...i need help to find my door sensors becuz my door light doesnt go off....i have no clue...i even slammed the shit outta my doors but its still on...when i drive i noticed that the light flickers on and off...but when i stop its stays on...any suggestions on whut i should do???
The Dome Light Door Sensors should be on the edge of the door frame, on the body not on the door.
they just push in, it is a little spring loaded switch that completes the circuit when the door is open if it is working properly.
The Sensor only has 2 small wires going to it on each side.
The Wire clips on to the sensor, the clip can be removed with needle nose pliers quite easile and voila, problem solved, but then the lights don't come on when the doors open!
The wire is behind the kick panel on either side of the back seat, you will see it if you remove the panel, i think it is the only wire near the edge of the door frame...!
