Can I fix it? Even if its just temporary?
D DILLIGAF Racing · Registered Joined Sep 23, 2002 · 54 Posts Discussion Starter • #1 • Sep 27, 2002 Can I fix it? Even if its just temporary?
S SuperblkStalion · Registered Joined Aug 26, 2002 · 124 Posts #2 • Sep 28, 2002 i have the same prob. i hjeard you just ahve to change the hinges and it will be ok jr
J Joshb13sentra · Registered Joined May 13, 2002 · 154 Posts #3 • Sep 28, 2002 Just switch the door hinges, Pain to do but it's the only way to fix them, You can either buy new hinges or rebuild the ones you have.
D deception se-r · Registered Joined Jul 24, 2002 · 152 Posts #4 • Oct 4, 2002 it actually is not that hard, it only took me about an hour to do both doors. it is likely you will only have to change the bottom hinge.
OPIUM · All over your face! Joined Aug 18, 2002 · 2,384 Posts #5 • Oct 4, 2002 What are they approximate cost of new hinges? I got the same problem...
D DILLIGAF Racing · Registered Joined Sep 23, 2002 · 54 Posts Discussion Starter • #6 • Oct 5, 2002 I got a price of $38 for each hinge
