Well
91sentra said:
how do you take off that lower map holder pocket thing on the B13 doorpanels? I couldnt find any clips when i took the panel off.
Once i removed the window guide from the top. the panel just "pop" out, had to work those little plastic plugs so they all wouldnt break. But it came out pretty easy
100NX2000
You have to remove the doorpanel itself. There are small phillips screws that screw it on the panel. Good luck. It is not hard to do!
