1 - 19 of 19 Posts
Supp all!
Was wondering if NE of you guys had experience in adjusting the door hinges?... My door gives a nice "KA-THUNK" sound to close it. What hapens is that it hits the latch but i have to pull in and up to close it properly.
Is there a way to do this adjustment with out dismanteling the front fenders? I was looking at it and it seems hard to get at the bolts without removing the front part of the car... :eek:
I tried the latch first, the door closed easily but it dont line up with the body when shut...
would appreciate the advise...
· Ex-mod/nissan guru
just buy the little bushing it will do the trick... ive replaced several of those and it works well... nissan sell those $$$$$... but its worth it !
the pin rarely need to be changed... unless its grooved..
Had the same problem with mine when I bought it. The pin for the door hinge had worked itself loose. Lifted up on the door and knocked the pin back in with a hammer. All's fine now. :)
Just got the bushings ($5.15 each) small metal pieces. I got 2 of them and will replace the bottom part of the door hinges. Will let you guys know the outcome.
Jon I'll check both doors and see if the both are in order. Thanks for the insight.
· Sentra Specialist
You will need at least one of the hinge pins replaced, the lower one. For a door that is as far out of alignment as you've described, you have gone far beyond wearing out the brass bushings. You now definately have at least one badly grooved pin. BTW, I have found the lower pin to be quite difficult to drive out at times. First, knock out the door check pin, to allow the door to open fully. I have modified a slightly curved air chisel bit, for the job. It works great. I say slightly curved, because you will find that you can't get a staight punch to contact the pin directly. There isn't enough room. Also, make sure you pack the new bushings in wheel bearing grease while putting them in. Lastly, the bushings and pins can be gotten at auto parts stores as well. I found them at my local Napa, on those cards hanging on the "Help" racks. Cheers :)
· Nissan/Mazda Gumshoe
good, ill definetly have to invest in some of those myself. hopefully, that will fix my problems too.
well, as blown predicted , my bottom pin on the driver side was looking pretty bad. to say it lost some weight would be an understatement! ill have to call in reinforcements for this one. ill keep u posted..
it took about an hour but i giot it done . the bottom bushing on my ds door was pretty much nonexistent. i put the new bushings and pins in and......no difference? i mean , i cant move my door up and down anymore but it still doesnt seat flush with the body when i close. i looked at the "hook" on the door and noticed that it was a little worn. ill either swap that out for another and if that doesnt work swap out the locking mech on the door and see if that doesnt fix it . as before ill keep u posted
· Sentra Specialist
*****Someone adjusted the striker lower, to acommodate the worn hinge pins. Now that they are new, you need to adjust the striker back it it was originally. Either that, or you'll need to adjust the hinges themselves, but I doubt it. Has your car ever been hit?
yes it was but this happened before i got the car . once i got it , i replaced the ds fender and drove. how exactly do u adjust the hinges
1 - 19 of 19 Posts
