Driver's side headlight would not work. Brights and daytime running lights would work. Checked/cleaned headlight switch, not relays in engine compartment, not a ground wire.
Daytime running light module located beside battery between battery and fender. 3 plugs on bottom, small square box. Remove battery, unbolt DRLM, unhook 3 connections, pry open box. Inside a circuit board, check soldering, one very small loose connection, resolder.
Thank You to other forum posters.
