1 - 9 of 9 Posts
P.O.S. Truckdriver
anyone ever installed a direct port nitrous system on a ga16de? i have a really good deal on a nitrous set up...wet i think. i'm not too into the idea of drilling a hole in my air intake pipe..or is that for a dry system? i dunno its late. please let me know.
You would have to drill a hole in your intake tube for either a dry or wet system. A GA16DE can't take a direct port system. The smallest safe setting is 80 horsepower. The rods will and pistons won't take to the shock of the Nitrous very long. It would work for a few passes I suppose. You need to build the bottom end up with good rods and pistons. Then put 120 shot on it.
P.O.S. Truckdriver
i know that you need to build the bottom end to support a larger shot of n2o....but is that the reason you said you cannot dp the ga16de or is it something with the manifold design?
Direct port is better but, you can only jet the 4 nozzels to a minimum shot of 80 horsepower. The range is from 80 -200 plus for 4 nozzles. The GA can only handle 50 horsepower safely. The manifold design is fine for direct port.
P.O.S. Truckdriver
alright mike..thanks man. i didn't know that the minimum jet was 80 hp either. if you can still order them for me i might be interested in getting those forged rods and pistons. btw, what shot are you spraying?
I am trying to see how many people are interested in the rods. I am in a lawsuit with a guy that was making the rods. I've found another sorce for them when we have a few people really ready for them. I only have a 50 shot and have gone through 72 bottles of nitrous so far. I haven't used it for about a year now that it runs so good on the motor. I need my SER injectors and then will try it again. I'm hoping for 13.9 in the 1/4.
P.O.S. Truckdriver
good luck man. the reason i never ordered the pistons was bc i was and still am confused with whether to go turbo or nitrous. i am running decent times right now with the few performance mods i have...but i just need to figure out what i want to do.
1 - 9 of 9 Posts
