I have an 1988 Nissan Sentra 2 door. My gas and temperature gauges do not work and my dash light just went out. I have searched for a fuse for the gauges to no avail. Help please.
There is a fuse in there for the gauges, you just have to get a 12volt continuity tester and check each fuse. Check the top row and to the right, it should say meter.
The dash lights are probably a bad fuse. The temp/gas gauge problem is common on B12s. I have it too There is a transistor in gauge cluster that is prone to failing. I'm not sure where it is but you would just have to solder a new one in. OR you can just ignore it like I do. Just reset your trip odometer after every fillup and know how far you can go on a tank of gas. BTW the low fuel warning light will still work So you could just drive the car until the light comes on and then get gas quickly.
Nissan Forums is the go to place to talk about your favorite Nissan model, including the Rogue, Maxima, Altima and even sports cars like the 370Z and 200SX.
