I have a 97 sentra and on 12/22/07 I replaced the drivers side cv axle. all went well except for having to drill out the cotter pin on the ball joint! Now I have a bad vibration the goes and comes with depressing the accellarator. Also there is tranny fluid leaking from behind the inner joint. This was not like this when I replaced the previous axle. Anyone have any ideas what the problem may be? I asked around and was told that the bearing in the transmission was bad and it was making it leak and vibrate. My thoughts are that the shaft is bad and caused the seal to leak and vibrate.
Any thoughts?
Any thoughts?
