HAVE REPLACE SPARKS, COIPS GAS PUMP BUT STIL .PUT THE SCANER BUT WONT READ. . CLEANED THE THROTTLE BODY BUT NOTHING. ITS HARD TO START BUT ONECE YOU PRESS THE GAS PEDAL IT TURN OFF. WANT TO CHECK THE TPS OND THE FUSE TO SEE IF I CAN GET A CODE FOR THE PROBLEM . CANT FIND THE PARAMETERS OF THE READING ON THE TPS TO SEE IF ITS BAD. ANY SUGESTION ON OTHER THINGS THAT IT MIGHT BE. ALL APPRECIATE ANY HELP.
ATT.RAUL
