Hi everyone (Noob here). I have a 2006 Nissan X-Trail, 2.5 petrol with LPG conversion. I purchased it as a none runner and managed to solve this.
Having the engine running I have found the crank shaft pulley seal has gone. No my problem, I have reviewed on this forum and researched You Tube and tried all the advices to no avail. The latest by borrowing a 480 Neuton impact driver and X-Trail still said no.
Can anyone provide any insight and had any experience in this matter.
Yes I have tried the method of locking off the wrench and using the engine crank method, this just split my socket and began rounding off the bolt head.
Sup Mod keeping the peace
You can try a 3/4" 600 ft-lb air impact wrench using 6-pointed impact sockets. If that doesn't work, spray the bolt area with PB Blaster, wait for several minutes, then tap the bolt head with a large hammer; repeat with PB Blaster and hammer. Air impact wrench again. If that still doesn't work, apply heat with an Oxy torch to the bolt head; air impact wrench again.
Discussion Starter #4
Hi, rogoman, thanks for the info. I managed to get the harmonic balancer pulley wheel off and the oil seal changed.
I resulted to using a breaker bar with a 19mm socket directly on the bolt (no extension bars as seen in many video) the breaker bar was then wedged against the suspension bar and engine turned over.
