P
Guest
My cooling fan is robbing HP when it engages. If I convert it to an electric fan, will this correct the problem? Do you have any other ideas??
How do I get more HP for the 3.0l engine??
intake/exhaust/pulley/efan/header can help with power. Also, use synthetics everywhere to free up HP---front/rearends/xmission/xcase/engine......
E-fan needs to be wired to a temp sensor and the A/C. It should also have an override ciruit breaker in the car in case the relay/fuse/temp sensor fails. When the E-fan kicks in, it will pull HP off the alternator. But, when it isn't working, the engine will be more quiet, warm up quicker(in the winter), and rev easier.
