all it does is cool the air.
most cold air intakes have to be plumbed (routing the intake tube), so as long as the brackets can be set to fit and the intake tube is same diameter, it should be fine.
but if you're wanting direct bolt on, no prob, just grab your wrench and go... get the one for your year.
but most likely, there's someone on here that would know if the 2 different years have any differences in the engine bay.
DNE's VZR Conversion
I have a 1999 Nissan Sentra SE and I have been looking around for cold air intakes for it. I have found like 1 but most of them are 2000. I was wondering can you use a 2000 intake on a 1999?
are you searching for sentra or for 200SX
the SE should have the 2.0 L motor and you can find brand like injen etc.
search for the 99 200SX SE-R it has the same motor and will fit the same
