1 - 14 of 14 Posts
I have a 90' 300zx NA.
I just got the master and slave cylinders replaced and a clutch put in not too long ago. It drove fine for about 2 days then today when i got in and started the car I pressed the clutch and the clutch just shot down to the floor.
I had to pull the clutch up with my foot.
My mechanic bled both the 2 lines.
I got a Regular EXEDY CLUTCH kit installed
Could it be the pedal itself?
Please help I was going to show it to a potential buyer today. Damn!!!
Power FC Z32
Call your mechanic and ask them what they want to do since it's the mechanics fault. When was this done done?
If the ydo nothing then you have to lift the car and see where the leak is coming from and fix it then add hydraulic fluid and rebleed.
Good luck.
the job was done about 2 days ago...I didn't find a leak around the cylinder. I filled and re-bled like 3-4 times and still no clutch pedal pressure it is still just hitting the floor and wont pop back up...
Discussion Starter · #10 ·
so it was leaking from the bottom but i got it tightened...i bled it like 6 times and still there is no pressure to the pedal
the slave cylinder was wet seemed like brake fluid...the little rod was not moving when the clutch was pressed.
Discussion Starter · #12 ·
i bled both top and bottom....the hoses were fine as well....i think i'm going to have to take it back to my mechanic....i didnt have this problem before it was just 2 days ago when i got the cylinders replaced....and today i had no pressure
thanks for your help Spongerider
Make sure your mechanic bench bled the master cylinder before it was installed, I'm probably mistaken, but don't the Z32's have a dampener ( I call it a dampener, it looks like a little box that the hydraulic lines run into) it also had to be bled and might be leaking too.
-Chris
Power FC Z32
-Chris
You're right about the bench bled and the damper has a line going from it to the power steering reservoir which allows you the bleed the dampner. We call it bleeding from the top.
1 - 14 of 14 Posts
