If I'm in first gear, and launch hard, get the rpm's in 6k+, then shift into 2nd, as I'm letting go of the clutch it kind of 'clicks' into place... it's hard to explain... its not really a problem unless I'm flooring it, then have to stop because it;s hard to start out without stalling (the clutch is disenganged, then 'pops' into fully engaged.) Also, the pedal doesn't feel smooth.. It's kind of almost "crunchy" feeling.... I lubbed the pedal linkages, and changes the clutch cable (due to cable stretching). I got the clutch replaced right after I bought the car, and I don't know if this was a problem before or not. What could someone do while installing a clutch to cause this? Also.. the clutch still engages while the pedal is too close to the floor even with a new cable and its adjusted all the way... Anything to do with installation?
