Hi, I have an '88 Pathfinder that I'm trying to put a new water pump in and my problem is the fan clutch doesn't actually have a nut to loosen it from the water pump pulley, only a round hub. I know you have to stabilize the pulley but I can't figure out how to loosen the fan clutch housing. Any ideas would be greatly appreciated. Thx.
Sup Mod keeping the peace
Remove the 4 nuts that attaches the fan clutch and pulley to the water pump. The 4 nuts are behind the fan clutch; you'll have to look from the side to see them.
NF Mod/Nissan Master Tech
The nuts are 10MM...and don't drop the lock washers taking them off! It might be easier if you unbolted the fan from the clutch, first.
