I replaced the battery in my 2012 Pathfinder and now the clock won't hold the correct time when I restart the car. Also when I restart, the radio resets to one certain station. I checked all the fuses I could find, but nothing seemed bad. Is there a way to reset? Or do I need to take it in to dealer or mechanic?
Joe
NF Mod/Nissan Master Tech
Your dealer would be your best bet; there may be a software update available. Also, if you are within 3-years/36000 miles, it should be covered under warranty.
Have you tried disconnecting the battery, wait a few minutes then reconnect the terminals. This is like turning off your computer when it hangs up. Worth a try before going to the dealer.
I've changed batteries many times over the years and never had an issue like this. If you do disconnect and reconnect the batteries, wait at least a couple minutes before reconnecting. But I would be looking more towards the radio as the problem. This problem doesn't sound right. Hope your under warrantee, and if so get it to them very soon.
Joe
Did you ever find a fix to this problem? I have had issues with the clock for years but now that I changed the battery it wants to set the clock to 4pm-ish no matter what time of day it is. :(
