Hi all,
I own a 1991 Nissan D21 Pickup with a KA24E that has approx. 276000 miles on it and runs quite well for a 16-year-old (going on 17 years old) truck with so many miles. Now it does burn some oil, mainly after it's been idling for quite a while (such as waiting at the bank drive-thru) then when I place load on the engine it puffs out a blue puff then afterwards just smaller amounts (minuscule) of blue smoke. I suspect (even though I have practically zero automobile knowledge, most of what I know comes from reading forums such as these) that the valve seals are pretty well worn and the piston rings are probably (saying "probably" is a joke after that many miles
) worn, but not as bad as the valve seals. Anyway that is kind of irrelevant.
As I was going to say before I got side-tracked, my main concern is occasional ticking (ticking noise is in unison with engine RPM) that comes in after several hundred miles of driving that sticks around for about 20-40 miles then goes away. From what I've read (such as this post) the issue seems to be lifter/valve noise? I'm worried if it might be rod knock or something but if that was the case wouldn't it have blown up by now after years of off-and-on noise?
Only "major" repairs I've had done to the vehicle was timing chain replacement (old one either snapped or the chain guides broke, not sure which,) exhaust manifold, and the fan clutch. Most of the other problems have been mainly the cooling system but the engine has never been allowed to overheat (or at least while I knew it was happening anyway.)
Sorry for the wall of text, anyway the main thing that is peculiar about this noise issue is that it ONLY happens after I've run the truck and it has warmed up, then I turn the engine off (say to go into the store,) then when I come back and crank the engine the noise is there and stays for 20-40 miles then goes away. Also, it does not seem like the engine's power is affected at all by this noise. Doesn't lug on me or hesitate or anything but that noise can be quite annoying and even embarrassing while it's happening!
The oil I am using is Castrol GTX 20W-50, is that the right kind of oil? My mechanic says to use that oil since it's a high-mileage engine and clearances are looser, and it makes it burn less oil.
Oh and I check all the fluids I know how to check once a week (oil, coolant, power steering, brake.) I just checked and I'm not low on oil even though it's clicking.
Any comments on this post would be greatly appreciated
