Alright so i just installed a tach with my friend and in the process of installing my friend attached the rpm signal wire to the wrong wire and after starting the car and realizing this i connected to the right wire. The next day i start up the car it runs fine I go somewhere then try starting the car and it wont start on the 3rd try it finally starts then my check engine light is on. Got that checked it says camshaft position sensor A- Bank 1 circuit malfunction and then the other one said Manufactor control Ignition system or misfire so i have no clue what this means. Would greatly appriciate help.
