I'm trying to pull the codes from my 1994 XE 4x4 4Cyl but as far as i can tell, this is done via a blinking check engine light....Well i don't see anything resembling a check engine light come on when i follow the procedure specified to check for codes....
I don't even see the light come on briefly when i turn the car on....Should it? what does it look like?
Moderator
Some models without CA emissions do not come with a Check Engine light. You have to watch the LED's on the ECU to check error codes.
I took my cluster out and there was a bulb there but the contacts weren't that great...I cleaned it up and now the light comes on when i turn the ignition on. Let's see if i can read any codes now. Thanks for the help!
